Ok so I dont have a picture. But if you are sitting in your truck the torsion bar crossmember is basically right under you. You should see a bar running from the lower control arm back to the crossmember. There will also be 2 bolts sticking out from the crossmember and all you have to do is to tighten them up. But I would jack up the front of your truck before you do it. Hope this helped I will try to find a picture for you
