Yukon finally lowered...
Polecat
Stillwater, OK
Looks good man. Did you make it to the TX Heat Wave after all? I remember you mentioned something about attending in a PM a while back.
Damn that turned out nice bro! You can pull the coil isolators for a little extra drop out back if you want but that looks 10x better esp with the paint work.
Big Tap
Austin, TX
That looks great man! Glad those shock extenders worked out for you.
What do the coil isolators do Boost?
Alex33
Coil isolators are rubber pads that keep the coil from rubbing on the pocket and making noise. They are more useful on some vehicles than others as some suspensions don't make much noise w/o them and some make a ton of noise w/o them.
Alex33
I'm answering questions and failed to mention how good the truck looks. great job!! keep up the mods.
Big Tap
Austin, TX
Hmmmm...thanks. Something to consider when I go to install my kit.
Polecat
Stillwater, OK
thanks all, and yes Big Tap, they worked perfect, thanks again...
I considered pulling the isolators, but then it'd drop almost another 1", but saw this ands was fine with the way it sat. :)
thanks all for the feedback and kind words...drives much better.
Rims are 20's with 285/50/20 Nitto 420S.
JKMotorsports, yes sir, went and got sunburnt at heatwave...did you make it?
JennaBear
CA
Very nice! When you gonna clear out those lenses??? Would really help set off that front end! Maybe some candy on the taillights too? Either way, still a nice lookin rig!
Polecat
Stillwater, OK
thanks Jenna, plan on getting the smoked LED taillights after the tune.
How do we clear the front lenses, or do we buy new headlight assemblies?
JennaBear
CA
I know with my clears, I just bought them, but I only had to worry about the lowers.
I will see if I can dig up the write-up for you, but I know of some people that "bake" the assembly in the oven for a bit, and the yellow just pops right out. I personally would not feel too comfy throwing my lights in the oven, and would see if I could find some to buy and swap out!
JennaBear
CA
Polecat
Stillwater, OK
amen, not to savy on putting my headlights into ovens...I'd rather buy aftermarket and swap out. :D
tybardy
on the top head lamps you can take the assembly out, pop it open and get the amber out without buying a new set (you shouldnt need to 'bake' them either... if you are having trouble, maybe just a hair dryer) , but you cannot do that to the bottom (the bottom assembly does not come appart), you will have to buy clears for the bottom, you can find a set for like $30 on ebay that is basicly the stock setup without the amber.
hope that helps, happy hunting..
diffrnt
MS
I really like how your truck sits, looks very nice. I see that it is an Eibach set up, but how much of a drop is it? I want to drop mine and your height looks perfect for me.
