02 Suburban 4hi headlight mod help!!
Sepiroth
Spam Executioner
Kouts Indiana
OK I searched different forums for over two hours. All i could find was info on 03 up trucks.
Can someone please help me out. I'd like to do this mod to my Suburban. 02
Behind the driver's side headlamp assembly, locate the harnesses to the low and high beam bulbs. The low beam should have a yellow and an orange wire. The high beam should have a purple and an orange wire.
The relay contacts are going to be wired as followed, and you only need to perform this on one side of the vehicle:
Relay Pin #
85 - Connects to purple wire from high beams.
86 - Connects to either orange wire, doesn't matter which.
30 - Ground.
87 - Connects to yellow wire from low beam.
87a- Not used.
tybardy
JK... do you know how to do the "6 on low" mod?
The mod where the lowbeams, DRL's and fog lights are all on at the same time while driving?
