ABS and Brake Light?!
davidsmith240
Littleton, Colorado
Hey guys,
My 2001 Tahoe, 170k miles, about every 15 min into driving...both of these lights will come on at the same time. I've discovered that I need to replace the EBCM! I'll let you know the results!
I have seen many videos where people open up their existing EBCM and solder some stuff...but at 170k miles, I think it's time.
alwyswntd1
On my 06 ppv Tahoe same thing happened,if you look under the drivers side,there are grounds connected there remove them sand the area and reconnect the ground that should do it.hope this helps
