You have to remove the entire door panel. The mirror access trim (triangular trim in the corner) unclips, the trim around the door handle unclips, and the trim around the manual lock switch unclips. Pull up on the power lock/window switch panel; it unclips as well. Unplug the harnesses. You'll have a 7mm screw behind the power switch panel trim, one underneath the corner of the door pull/armrest, and another behind the manual lock switch. Once you have these parts removed, you have to pull up on the door panel. After you get the door panel off, you'll have to unclip the bulb from the door light, unclip the tweeter harness, as well as the heated seat switch harness if equipped.
Sorry I don't have any pics to show you more in detail. If I remember, I'll try to snap a few tomorrow for you.
