EricCartman
- Jul 20, 2008
Hi All,
I'm trying to help my father figure out what is going on with his 2004 Tahoe. It seems to be displaying 0C on the temperature display.
I did some preliminary searches on google... and I found that in all likely hood the 0C = Open Circuit - meaning one of two things...
1. The temperature sensor is disconnected
2. The temperature sensor is bad.
To throw an additional wrinkle in the mix... the windshield was replaced while the vehicle was sitting.
I'm wondering if perhaps the wiring could have been disconnected in the process of replacing the window. It seems like it could be possible, but I want to make sure that it actually is before I call and ream out the windshield replacement company.
Also - I am trying to locate the senor for the temperature. I believe if I find the correct wiring harness that plugs into the mirror/sensor - if I jumper across the pins with a paperclip it will read 5C = short circuit.
If I can induce the 5C condition... at least I will know the mirror is still connected to the other end of the harness - and that the sensor is bad.
However, I do not know where to find the sensor. Some folks have said it is on the radiator support bar, other say near the tranny.
I'm a little nervious to find something that I *think* is the correct jumper and putting a short across it. Not a fan of smoke and fire in a vehicle.
I believe I found it... but I'm hoping someone could either refer me to a schematic diagram for this system - or could confirm the wire colors/location of the sensor circuit.
I know... I should buy a Hayes/Chilton or some other brand manual for this thing. But, I haven't got around to that yet. Ideally, I would like to have the FSM. Anyone know where I can find an electronic copy of that?
Anyway, any input would be greatly appreciated.
Thanks,
Cartman
Thanks,
Cartman
