Getwired
2007 Yukon Fog Light Mod - USE LEDs or HID bulbs ONLY!!!
Wow, I saw this slick mod referenced here, and I have to try it on my Denali! I'm gonna try it tonight and see how it works out. I haven't been impressed with the NBS fog lights or headlights since day one... To complete the mod, I found some fog light assembly removal instructions here, but I've included them here for easy reference. I picked up some Sylvania Silverstar 9005XSST's (twin pack) from Pep Boys, with a $10 rebate, and the wiring harnesses and crimp connectors. Easy to find stuff I guess.
EDIT: DO NOT USE ANY BULB OVER 40W -- SEE BELOW -- CAUSES HEAT DAMAGE. Stick with a HID bulb, or an LED bulb instead. The Sierra uses 5-1/4" fog lights (assembly looks identical, it's just larger) and Yukon uses 4" fog lights. The smaller size makes all the difference.
Maybe I'll post some pics in the next day or so -- we'll see how well it goes!
Man, this is fun!
Front Fog Lamp Replacement (Yukon)
Click image for full-size version.
Preliminary Procedures
Disconnect the electrical connector from the fog lamp bulb socket.
Tip - Fog Lamp Upper Retention Studs (Qty: 2)
Ensure the retainers are repositioned into the front bumper fascia mounting holes prior to the installation of the new fog lamp if they become dislodged during the removal of the lamp.
Tip - Fog Lamp Adjuster Screw
Adjust/aim the front fog lamps after the new fog lamps have been installed.
Tip - Fog Lamp Assembly
Remove the bulb socket from the lamp assembly and transfer as necessary.
Man, this is fun!
- Remove either the LF or RF wheelhouse liner.
- From the inside of the front bumper fascia, using a blunt instrument, pinch the retainers and push outward on the 2 upper mounting studs for the fog lamp.
- Using the same blunt instrument, pinch the retainer and push outward on the lower adjustment screw for the fog lamp.
