one headlight brighter then other?
1sik_hoe
so i have had a problem with one headlight being way brighter then the other i have tried a new ballast hid kit and also new lights with no luck,any one know of what might need done to fix this or has this happened to any one else? thanks
gibsonsynthetics
Medfield, MA
I am not entirely sure as I have not encountered that problem before, but it almost sounds like there might be a connection problem. Frequently if there is a bottleneck in the wiring it can cause high resistance thus reducing the current making it to the end result of light. If you have a voltmeter/ammeter try checking how much current is making it to each of the bulbs. If the numbers are different I'd look at your connections. Hope this is helpful.
